make assembly more simple
auri_z
use assembly for program microcontroller (PIC!6F877A) always same code repeating. how to write code more simple.
for example
    cblock    0x26
                temp1,temp2,temp3,temp4,temp5,temp6,temp7,temp8,temp9
                temp10,temp11,temp12,temp13,temp14,temp15,temp16,temp17
                temp18,temp19,temp20,temp21,temp22,temp23,temp24,temp25
                temp26,temp27,temp28,temp29,temp30,temp31,temp32,temp33
                temp34,temp35,temp36,temp37,temp38,temp39,temp40,temp41
                temp42,temp43,temp44,temp45,temp46,temp47,temp48,temp49
                temp50,temp51,temp52,temp53,temp54,temp55,temp56,temp57
                temp58,temp59,temp60,temp61,temp62,temp63,temp64,temp65
                temp66,temp67,temp68,temp69,temp70,temp71,temp72,temp73
            endc
can code above make more simple like:
cblock    0x26
                temp1,temp2,temp3...temp73
in my program also use same repeating code send data to PORTD, like
        movf        temp1,0
                 movwf      PORTD
                 call          tunda
                 movf        temp2,0
                 movwf      PORTD
                 call        tunda
                 movf      temp73,0
                  mvwf    PORTD
                  call       tunda
code above if write less efisien, how to make code more simple.
like in C can write
for temp=1;temp<73;temp++
movf temp
movwf PORTD
call tunda
The motivation for creating the C-programming language was to make "assembly more simple". I believe that C (with modern compilers) is more efficient than assembly written by mediocre programmer.
it's true C more simple than assembly, but my program was assembly. my instructor at school assign to make my program more simple in writing.
my code just repeating same code, i think there is away make my program more simple but i don,t know.
maybe someone with more exprience know what i don't know.
thnk
thnk
If your program code has the same block of code many times, consider writing a MACRO for that block.
NOTE: it will not make the assembled hex file any smaller but it will make writing the code text easier and the listing shorter.
Ok, sorry I miss-understood your question. It seems that you need to learn how to write arrays (tables) and program loops etc. in assembly. I hope someone here can give you good advice. I use assembly only in critical places of my C-programs.
i also think array or indexing can make simple, but i don't know how to use array or indexing in assembly . i now try to undestand it's. so far not found yet good references or good sample.
Look at page #10 of this pdf..
Also this tutorial link should help you.
Elmer 160 -* Course Lessons
  • PIC_Base_A_11.pdf
You can use indirect addressing,
		movlw	temp1
		movwf	FSR
Loop		movf	INDF,w
		movwf	PORTD
		call	tunda
		incf	FSR,f
		movfw	FSR
		xorlw	temp1+73
		btfss	STATUS,Z
		goto	loop
I agree. Define the array like this;
        cblock  0x26
temp:73                         ; unsigned char temp[73]
        endc
Then access each array element directly in the operand like the example below or indirectly as per Mike's (Pommie's) example;
        movf    temp+d'0'       ; WREG = temp[0]
        movf    temp+d'22'      ; WREG = temp[22]
        movwf   temp+d'72'      ; save to temp[72]  // last array element
thank to all..
today i can make my program more simple and short.
my code after using indirect addressing just 11 line for display data to PORTD and clear just 10 line, original 216 and 72
  movlw     temp+d'0'        ; first array
            movwf    FSR
Loop      movf      INDF,w            ;move content register
            movwf    PORTD
            call        tunda
            incf        FSR,f
            movf      FSR,w
            movwf    test
            xorlw      temp+d'72'
            btfss      STATUS,Z
            goto       Loop
            return
