Making a sinusoidal power waveform from two halves?
Flyback
The attached shows two voltage sources. Between them they contain the full 50Hz sinusoid power waveform.
One contains the positive going half sines.
The other contains the negative going half sines.
Can you think of a better way than the attached to amlgamate them to give the full sine?
The attached is just Bi-Di switches going at 10ms period.
  • Making the Sine.asc
How is your second (bottom) voltage source created? Making a half-wave without a connection to circuit ground and a perfect half wave is quite a feat from my point of view.
Because AC sine sources for testing SMPS are hideously expensive.
This is simulation and the equivalent of pulling your brains out through your left ear. You need to switch to Art History for a hobby.
