I've put together 2 x 16f628 pics and have followed Nigel's pic on RF transmission using Manchester encoding.
If I connect the PIC tx pin to the other PIC rx pin the word "Nigel" is sent on the one PIC and received and displayed on the serial port correctly. Everything A-ok.
I've now put a 433Mhz receiver and transmitter in the loop as per tutorial 12.1 and when transmitting "Nigel" its only received about 50% correctly on the receiver side. Most of the time one of the letters is missing (ie. Ngel or Nige)
I think its got to do with the 433Mhz modules I've got - they are only 2400 baud (Sparkfun tx and rx
In the transmit:
And receive code:
I figured these are the values that sets the timing.
My first question - is the tutorial code configured for 9600 over wireless? It says 9600 baud but I think thats for the RS232 comms.
I thought to change it to 2400 baud I could just multiply the .115 and .39 by 4 - clearly its a total guess as it didn't work. After changing that I don't receive anything.
How would I go about changing the code to work with a 2400 rx/tx? I hope its something simple as I'm so close to get it working![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Here's the for Nigel's tut.
Otherwise I might be completely on the wrong track and its not a timing issue.
In the transmit:
mtx_init movlw .115 ; 350 usec
movwf mtx_delay
return
And receive code:
T EQU .39 ; half frame 350 usec (= T * 9 usec)
