ChrisPDuck
OK, i've had this clock a while, ( it has a LED matrix display) and it has a feature that between the hours of 9pm and 6am it dims the display.
Instead of just dimming the display, it has started to cause it to flicker ( noticeably)
i'm guessing its due to the PWM being messed up somehow, but i can't figure out how.
The Circuit has 3 IC's, two being "Octal D-type transparent latch" according to data sheets, and the third i can't identify.
I've taken some photos of the board, can provide more detailed shots if you think it would be useful
Clock board - a set on Flickr
I've already tried replacing the caps, but that didn't seem to help![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
If you have any ideas about how this can be fixed, that would be really usefull![Big Grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
If not, i want to try and "rebuild" the clock, so i would need to find a way of creating a circuit that could use the existing LED front, so i would need to control a 22 pin header, not sure how easy that would be.
Thanks in advance![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Quack!
Thanks in advance
Quack!
