I know, idle current and load current A but my meter will not read load current B. How do I find current for load B ???
Electronic device is turned ON but has no load, idle current is 6.2 amps.
Electronic device is turned ON pulling a medium size load and current is 18.6 amps.
Electronic device is on pulling a bigger load, my meter will not read more than 20 amps?
I put a .4 ohm resistor in the circuit to read voltage across the resistor. 3 voltage readings for all 3 loads, 1.22v, 4.4v and 5.18 volts.
How do I find amps for load B ?
