max232 cap
homemade24
I looking at using a max232 and it show 2 charge pump caps. anything special
about these or will any elect. cap the right size work
thanks
thanks
Electrolytics are often used with no problems, use the recommended values with a 16Vwkg rating.
use the MAX233 - no external charge pump caps - same function. Everything is on board already.
Boncuk
Yes that's correct. But you can get the 232 chip significantly cheaper, even including the price of the caps.
also, be aware that there is an A version (232 vs 232A) that uses smaller caps. I prefer the A since I can use ceramics.
I've used monolithics quite successfully in at least 5 designs. Like any other charge pump, just make sure they're voltage-rated higher than your output voltage.
