If you put the scope in series with the load, then you will just measure the open circuit voltage of the amp. The high impedance of the scope prevents any significant load current from going through the speaker.
As Nigel said, you have to put a small resistor in series with the load and measure the voltage across that to get the current.
It would help if you did some study on series and parallel circuits.
