It is DC.
Which resistor should I use? The voltage rating for resistor is 200V!
well if you are of a mind to spend more than you need to to be cool, you can buy a HV precision resistor, but you would be better off putting 10 resistors in series minding the power dissipation.It is DC.
...Coating with wax or some other basic insulator of the leads will be required as 2kv can arc through about 2cm's of open air.
what are you using 2kv for?
and at what amps?
I just dont see that in these threads that often.
Umm Aryan, I worked at a electroplating shop for 10 years, typical voltages are between 6 to 12 volts... If you're using 2KV it's not 'electroplating' it's powder coating?
I'm still confused, anodizing uses voltages in the 15-20 volt range. You really need to clarify what you're doing. You can't put that kind of voltage through a fluid, it'll explode.
