It has been talked about. There should be information on the web about this but it may take some digging. Some motors may work better then others. Give it a try.
Hi.
Would it be possible to measure the rpm of a dc brushed motor with a hall effect sensor? <...>
I'm setting the voltage so I know which direction it should spin at. The problem is if I change the direction abruptly the motor won't change the direction instantaneously. I'm primarily interested in the direction of the motor during this transition.
Inktomi said,I'm pretty sure it will still be going the same direction until it reaches zero RPM then it will go the other way! If it does not go either of these directions you may need to publish a research paper on it! or get a new motor.![]()
I think he meant, "The problem is if I reverse the voltage abruptly the motor won't change the direction instantaneously."The problem is if I change the direction abruptly the motor won't change the direction instantaneously.
Inktomi said,I think he meant, "The problem is if I reverse the voltage abruptly the motor won't change the direction instantaneously."
