Hi all,
I cant figure out how to calculate the current from a photodiode!
I am using a photodiode in reverse bias to detect and infrared signal incident on it from a transmitter.
Have built the recieving circuit by incorporating a gyrator circuit- as a constant current source to the LED.
when a signal of the frequency of interest in incident on the photodiode, the time constant of the photodiode is such that it cannot react fast enough, hence producing a low signal at the end of the photodiode. This low signal is then rectified and amplified by a transimpedance amplifier.
(For circuit diagra, - refer: http://generous.boy.googlepages.com/photodioderecievingcircuit)
Have the circuit going. I was wanting to test the accuracy of my circuit, hence:
How do i calculate the amount of current that is top be produced by the photodiode? (for experimental pursposes keeping the height of the transmitter constant at 5 cm and moving the transmitter away from the reciever to 1 cm, 2 cm. 3 cm and so on)
the photodiode i am using is a BP104 (https://www.electro-tech-online.com/custompdfs/2006/11/ZD-1947.pdf)
the transmitter generic 5mm (**broken link removed**)
I am driving the LED for short bursts at 1A.
any ideas?
any ideas?
