measuring temperature circuit with 7107.
joshua.svn
dear friends,
i have a measuring temperature circuit whose out put is 0 to 2 volts. i want this to interface with
icl 7107...
my circuits working with input voltage 24 volts converted to virtual ground say +12v 0 -12v.
duel supply.....
can any body give me an idea how to interface this 0 to 2 volts with my circuit.
because this working with duel supply.. with +12v 0 -12v.
i am confused with 7107 pins 0f 21, and 30 .31. 32, 35 and 36...
because it is confusing regarding supply different conditions mentioned in data sheet,
kindly give some schematic help in this regard...
svn.
If you post your circuit diagram of the measuring temperature circuit, it will be helpful.
E.
You will fry the chip if you use a +12V,0,-12V dual supply. The absolute maximum ratings are +6V and -9V.:(
