You mean to discharge the capacitor when it is turned off?dknguyen said:It is for when it is off. It is large to have neglible drain on the capacitor when in operation, but small enough (much less than an open circuit) so the capacitor doesn't retain it's high voltage charge for a week after it is shut off (where someone might touch it and get zapped).
They aren't exactly self-charging, but some types of (e.g. oil) capacitors store energy deep in the dielectric (while in use) and it comes to the terminals with a very long time constant (after the circuit is turned off).I remember reading somewhere about capacitors "self charging" over a long period of time when left open circuit - could be something to do with that.
Yes.You mean to discharge the capacitor when it is turned off?
picbits said:I remember reading somewhere about capacitors "self charging" over a long period of time when left open circuit - could be something to do with that.
But the capacitor will discharge to the load when the power is turned off, even there is no Mega ohm resistor right?mneary said:Yes.
No Computer Power supplies not designed to discharge through the Motherboard. They used switch mode systems.bananasiong said:Gayan, do you mean to prevent the capacitor from discharging to the load?
Yeah. It might take too long to discharge the capacitor to safe levels without a resistor. It is so it won't retain a charge for so long. Imagine touching a high voltage capacitor inside a machine that was turned off a week ago and getting killed.bananasiong said:You mean to discharge the capacitor when it is turned off?
Yeah but it can take too long. For high voltage things it's a hazard. For a computer...I woudl think it's so the caps could discharge faster so you could reboot the computer soon after it's turned off for whatever reason.bananasiong said:But the capacitor will discharge to the load when the power is turned off, even there is no Mega ohm resistor right?
*Edit:
fingers said:Thanks guys this is most helpful! And it would be in the Meg ohm range rather than K's or less so that it doesn't draw much current when powered up?
The equivalent circuit is another smaller value capacitor with a high value series resistor connected in parallel with the capacitor.gootee said:There's also a phenomenon known as Dielectric Absorption, where capacitors partially recharge from energy that was temporarily absorbed by their dielectric materials. The mil-spec test for it involves charging with a certain voltage, for a certain length of time, disconnecting them for a certain length of time, and then measuring their voltage. But that's just the test. They also exhibit the associated behavior while in use. That's why, for certain types of circuits, it's very important to use capacitors with a low dielectric absorption specification. Teflon, polystyrene, and polypropylene film dielectrics are among the best, in that regard.
- Tom Gootee
