msovais said:hey can i use 150uh inductor instead of coils?
jpanhalt said:I used the TDA0161 and commercially available unshielded, open "bobbin" inductors, such as the Miller power inductors (Digikey p. 1216, P/N M8573CT-ND), with inductances of 470 and 1000 uH and got very good detection at 1 cm, and decent detection at up to 2 cm. My target was a 3/16 steel rod. A larger diameter coil might give more range. John
chemelec said:A Pot Core with Litz Wire will give the Best Results.
jpanhalt said:The results I gave were intended only as a brief summary of a series of experiments I did. Those experiments looked at oscillator frequency (28 to 60KHz), inductance, wire (Litz vz. magnet wire), and free-air resonance frequencies of the coils. At the frequency ranges tested, Litz wire made no difference. I also tried a few pot cores and got virtually the same results.
Thus, using small coils of the size described and 3/16" wire (hard-drawn, high-carbon music wire) and under the conditions of my experiments, the TDA0161 can be depended to provide good sensitivity up to 1 cm, and usable sensitivity up to almost 2 cm; however, to get above 1.5 cm, the settings are a bit "touchy."
On the other hand, with a two-coil detector (basically a Zircon metal detector -- a reverse-engineered schematic is available on the internet), I got sensitivities of 5 cm or more.
John
chemelec said:But if you want distance, why not just build a Good detector and get 10 inches or more on a Quarter.
chemelec said:Never seen that Zircon Schematic.
Take care...Gary
