MicroC Code Problem in DC controller
ishah
Hi, Can someone help me on the code push button. I'm doing the DC motor interface with PIC16f877A. I want the button to control all the movement (forward, reverse and stop). Current situation for my code,when I push the forward button, 2 motor will run forward and vice verse for the reverse button.
But I want is, when I keep pushing the forward button,the motor will move. and when i release the button .. the motor will stop.. so i dont need the stop button to control.
Thanks and here is the current code
    This source code is use to control the 2 motor movement by select
    the appropriate state button (Forward and Reverse).
//define motor1 ports
#define motor1a PORTD.F0
#define motor1b PORTD.F1
//define motor2 ports
#define motor2a PORTD.F2
#define motor2b PORTD.F3
//define controller 1 ports
#define switch_frwd PORTB.F1
#define switch_stop PORTB.F2
#define switch_rvs PORTB.F0
void main()
//set I/O port
   TRISB = 0XFF;
   TRISD = 0X00;
   CMCON=0X07; //      or CMCON register = 0X00000111
   ADCON1=0X07; //     Configure ADCON1, or ADCON1=0X06;
   switch_frwd = 0X00;   //set initial port = 0
while (1)
   if(switch_frwd == 1)    //If the switch is pressed
         motor1a  = 0;
         motor1b  = 1;    //Motor Forward
         Delay_ms(30); //1 Second Delay
   else
   if (switch_rvs == 1)    //If the switch is pressed
         motor1a  = 1;
         motor1b  = 0;    //Motor Reverse
   else
   if (switch_stop == 1)    //If the switch is pressed
         motor1a  = 0;
         motor1b  = 0;    //Motor Stop
         motor2a  = 0;
         motor2b  = 1;    //Motor Forward
   else
         motor2a  = 1;
         motor2b  = 0;    //Motor Reverse
   else
         motor2a  = 0;
         motor2b  = 0;    //Motor Stop
Just remove the two lines that say " if (switch_stop == 1) //If the switch is pressed"
i.e.
void main()
//set I/O port
   TRISB = 0XFF;
   TRISD = 0X00;
while (1)
         motor1a  = 0;
   else
         motor1a  = 1;
   else
         motor1a  = 0;
         motor2a  = 0;
   else
         motor2a  = 1;
   else
         motor2a  = 0;
Why Three times?
Learn how to use a state transition diagram as apart from a flow chart and your answer will drop out easily.
I know we all write code differently, but a switch statement would make it much easier to read.
At a quick look, have you catered for don't care states where both are pressed together.
Why Three times?
Sorry, Im newbie in this field, it is a typing error. I wrote the new one.
void main()
//set I/O port
   TRISB = 0XFF;
   TRISD = 0X00;
   switch_rvs = 0X00;   //set initial port = 0
while (1)
         motor1a  = 0;
         motor2a  = 0;
   else
         motor1a  = 1;
         motor2a  = 1;
   else
         motor1a  = 0;
         motor2a  = 0;
Can you give example as your
