S
Souper man
Guest
MPLAB IDE refueses to work, so I need a programmer and software.
I am using a 16F877A.
So is it your position that MPLAB does not seem to support the CCS compiler although you think it should? Checksum.dll sounds like the sort of thing that could have multiple explanations. The most charitable explanation would be a corrupted .dll, but whose .dll Can you establish weather it belongs to MPLAB or the compiler. Of course your copy of the compiler is a legitimate one - right?Souper man said:I am getting the following error:
Error 1904. Module c:\programfiles\microchip\MPLABIDE\---\checksum.dll failed to register HERESULT 2147220473 contact your support personnel
where the --- is, that would be part of the programming language. It would display every programming language except for CCS compiler
how can I write programs in MPASMWIN?
blueroomelectronics said:Either your XP is a mess or you don't have admin rights.
Why can't you reinstall XP, I do it about once a year as XP gets screwy.
And it's not just MPLAB, you don't seem to be able to get even PICProg running. So it's doubtful you'll be able to get any other programmer software running.
ericgibbs said:Hi,
I also have to clear and re-install XP Pro and SP1/2 about once a year.
blueroomelectronics said:You should learn how to slipstream service pack 2 on to an XP CD. Then when you reinstall it'll have the service packs already preinstalled.
I run MPLAB on a 1.7GHz laptop and it's fine. Nothing unusual.
ericgibbs said:Thanks,
I'll make that my next rainy day job.
Do you have any links to the slipstream method?
