microcontroller output: lsb vs hsb
hani_a
The microcontroller I'm using outputs the least significant bit first, for example, if i want to output 0x1b 0x54 0x0d i get the following at the output:
1011 0000 0010 1010 1101 0001
the analog device i'm programming expects 0x1b 0x54 0x0d at the input... while the above become b0 2a d8 , does it matter which bit is output first, highest or in this case lowest?
hani a.
It really depends on the receiving device, but if you are programming it then it shouldn't be a problem right?..... For example serial comunications RS232 sends the data with the LSB first,
Good Luck
Ivancho
