Do you mean this (see attachment) When the switch is closed, the input of microcontroller is high or low or floating?Normally you use pull-up resistors on a micro-controller, so common to ground (as you said) and the other two via seperate pull-up's to 5V, and also connected to two micro-controller inputs - so you can check either way.
However, this is rather a waste of two input pins, connecting just one will tell you the position of the switch - using either the normally open, or normally closed, is really up to you.
bananasiong said:Do you mean this (see attachment) When the switch is closed, the input of microcontroller is high or low or floating?
Yes, I got it. Thank you.Nigel Goodwin said:That's it, the pin can only be high or low, it can't float.
