Sinedup
Common +5V, common ground, decouplers between?
Hi all.
In a distributor's catalogue selling the 510 Scanner IC, (touch-sensitive MIDI), a simplified schematic of a generic (no brand) keyboard controller is added.
Looking at the way the miniature circuit is drawn, it appears that all 20x 0.1uF caps (decouplers) are connected in parallel between +5V (pin 16) and ground, which appears (IMHO) equivalent to one 2uF mini-disc cap.
Is this normal?![Er... what? o_O o_O](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
The suppied schematic shows +5V bridged commonly to IC pins:
IC1(16&13), IC2(16&6), IC3(16), then IC4>IC19(16&6).
But then it also shows C3>C21 (0.1uF) bridged commonly to ground on one side, the other leg going to all (p16)'s of IC1-IC19.
It then has C22 (0.1uF) again, between IC1(p16) and ground (parallel with original 'circuit listed' C3 in same position).![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
The E510 IC is apparently discontinued (WWW/Google research), but hopefully I can still find one here (RSA) or get a listed equivalent.
Main question is the 'parallel' decoupling caps & C3-C22 conundrum.
Maybe I'm missing the boat but this puzzles my brain-cell.![arghh :arghh: :arghh:](/styles/default/xenforo/smilies/arghh.png)
Microscopic circuit from components catalogue was abbreviated and re-drawn using Circuit Wizard.
Original Hi-res scan too large for posting (13Mb) & book is probably copyrighted anyway.
Hi all.
Is this normal?
