etekamba
Hi guys,
I'm kinda stuck with this code, it compiles without errors but I can't debugg it to know why it is not executing the part where it accepts passwords during simulation on proteus.
What's it supposed to do? Turn off LEDs on port A when passcode is inputed. I've attached the proteus simulation project for your info. Thanks in advance.
unsigned short kp, pwd[4], l01, l02, l03, l04, l05, l06, pchk;
int i;
char keypadPort at PORTD;
sbit LCD_RS at RB2_bit;
sbit LCD_EN at RB3_bit;
sbit LCD_D4 at RB4_bit;
sbit LCD_D5 at RB5_bit;
sbit LCD_D6 at RB6_bit;
sbit LCD_D7 at RB7_bit;
sbit LCD_RS_Direction at TRISB2_bit;
sbit LCD_EN_Direction at TRISB3_bit;
sbit LCD_D4_Direction at TRISB4_bit;
sbit LCD_D5_Direction at TRISB5_bit;
sbit LCD_D6_Direction at TRISB6_bit;
sbit LCD_D7_Direction at TRISB7_bit;
void enter(){
do {
  i = 0;
  kp = 0;
  do
   kp = Keypad_Key_Click();
  while (!kp);
  switch (kp) {
   case 1: kp = 49; break;
  pwd[i] = kp;
  i++;
} while(1);
void main(){
Keypad_Init();
ADCON1  = 7;
CMCON = 7;
TRISA = 0x00;
Lcd_Init();
Lcd_Cmd(_LCD_CLEAR);
Lcd_Cmd(_LCD_CURSOR_OFF);
Lcd_Out(1,1,"LINEMAN");
Lcd_Out(2,1,"PROTECTION");
Delay_ms(100);
Lcd_Out(1,1,"Initializing...");
Delay_ms(500);
pchk = EEPROM_Read(0x00);
Delay_ms(100);
if(pchk == 0x00){
  EEPROM_Write(0x01,0x01);
  EEPROM_Write(0x02,0x01);
  EEPROM_Write(0x03,0x01);
  EEPROM_Write(0x04,0x02);
  EEPROM_Write(0x05,0x02);
  EEPROM_Write(0x06,0x02);
  Delay_ms(500);
l01 = EEPROM_Read(0x01);
l02 = EEPROM_Read(0x02);
l03 = EEPROM_Read(0x03);
l04 = EEPROM_Read(0x04);
l05 = EEPROM_Read(0x05);
l06 = EEPROM_Read(0x06);
Delay_ms(500);
Lcd_Out(1,1,"LINE 1: ON");
PORTA.B0 = 1;
PORTA.B2 = 1;
PORTA.B3 = 0;
Lcd_Out(2,1,"LINE 2: ON");
PORTA.B1 = 1;
PORTA.B4 = 1;
PORTA.B5 = 0;
enter();
enter();
enter();
enter();
if(pwd[0]==42 && pwd[1]==42 && pwd[2]==49 && pwd[3]==35){
  Lcd_Out(1,1,"Enter Old L1 Pwd");
  enter();
  enter();
  enter();
  enter();
  if(pwd[0]==l01 && pwd[1]==l02 && pwd[2]==l03 && pwd[3]==35){
   Lcd_Out(1,1,"Enter New L1 Pwd");
   enter();
   enter();
   enter();
   enter();
   Delay_ms(500);
   EEPROM_Write(0x01,pwd[0]);
   EEPROM_Write(0x02,pwd[1]);
   EEPROM_Write(0x03,pwd[2]);
   EEPROM_Write(0x00,0x01);
   Delay_ms(500);
if(pwd[0]==42 && pwd[1]==42 && pwd[2]==50 && pwd[3]==35){
  Lcd_Out(1,1,"Enter Old L2 Pwd");
  enter();
  enter();
  enter();
  enter();
  if(pwd[0]==l04 && pwd[1]==l05 && pwd[2]==l06 && pwd[3]==35){
   Lcd_Out(1,1,"Enter New L2 Pwd");
   enter();
   enter();
   enter();
   enter();
   Delay_ms(500);
   EEPROM_Write(0x04,pwd[0]);
   EEPROM_Write(0x05,pwd[1]);
   EEPROM_Write(0x06,pwd[2]);
   Delay_ms(500);
  Lcd_Out(1,1,"LINE 1: OFF");
  PORTA.B0 = 0;
  PORTA.B2 = 0;
  PORTA.B3 = 1;
  Lcd_Out(1,1,"LINE 2: OFF");
  PORTA.B1 = 0;
  PORTA.B4 = 0;
  PORTA.B5 = 1;
while(1);
OMG! I was so stupid. I copied the first switch statement and pasted it so i can edit it later to other cases instead of typing them one-by-one. Alas, i forgot to edit them. But i've done that now and its still the same. Still doesn't process past the "LINE 1: ON" and "LINE 2: ON" screen.
This is the new code:
int i;
void enter(){
do {
  i = 0;
  kp = 0;
  do
  while (!kp);
  switch (kp) {
   case 2: kp = 50; break;
   case 3: kp = 51; break;
   case 4: kp = 52; break;
   case 5: kp = 53; break;
   case 6: kp = 54; break;
   case 7: kp = 55; break;
   case 8: kp = 56; break;
   case 9: kp = 57; break;
   case 10: kp = 42; break;
   case 11: kp = 48; break;
   case 12: kp = 35; break;
  pwd[i] = kp;
  i++;
} while(1);
void main(){
Keypad_Init();
ADCON1  = 7;
CMCON = 7;
TRISA = 0x00;
Lcd_Init();
Delay_ms(100);
Delay_ms(500);
Delay_ms(100);
if(pchk == 0x00){
  Delay_ms(500);
Delay_ms(500);
PORTA.B0 = 1;
PORTA.B2 = 1;
PORTA.B3 = 0;
PORTA.B1 = 1;
PORTA.B4 = 1;
PORTA.B5 = 0;
enter();
enter();
enter();
enter();
  enter();
  enter();
  enter();
  enter();
   enter();
   enter();
   enter();
   enter();
   Delay_ms(500);
   Delay_ms(500);
  enter();
  enter();
  enter();
  enter();
   enter();
   enter();
   enter();
   enter();
   Delay_ms(500);
   Delay_ms(500);
  PORTA.B0 = 0;
  PORTA.B2 = 0;
  PORTA.B3 = 1;
  PORTA.B1 = 0;
  PORTA.B4 = 0;
  PORTA.B5 = 1;
while(1);
Removing it from the routine and setting it just before enter() is called should fix that, or no?
New code:
int i;
void enter(){
do {
  kp = 0;
  do
  while (!kp);
  switch (kp) {
  pwd[i] = kp;
  i++;
} while(1);
void main(){
Keypad_Init();
ADCON1  = 7;
CMCON = 7;
TRISA = 0x00;
Lcd_Init();
Delay_ms(100);
Delay_ms(500);
Delay_ms(100);
if(pchk == 0x00){
  Delay_ms(500);
Delay_ms(500);
PORTA.B0 = 1;
PORTA.B2 = 1;
PORTA.B3 = 0;
PORTA.B1 = 1;
PORTA.B4 = 1;
PORTA.B5 = 0;
i=0;
enter();
enter();
enter();
enter();
  i=0;
  enter();
  enter();
  enter();
  enter();
   i=0;
   enter();
   enter();
   enter();
   enter();
   Delay_ms(500);
   Delay_ms(500);
  i=0;
  enter();
  enter();
  enter();
  enter();
   i=0;
   enter();
   enter();
   enter();
   enter();
   Delay_ms(500);
   Delay_ms(500);
  PORTA.B0 = 0;
  PORTA.B2 = 0;
  PORTA.B3 = 1;
  PORTA.B1 = 0;
  PORTA.B4 = 0;
  PORTA.B5 = 1;
while(1);
A similar project which I had done a few years ago. Here is the code.
unsigned short kp;
char uart_rd;
char code1[15] ,user1[4];
int i = 0, j, cnt = 0;
int w1;
//keypad module connections
//end keypad module connections
//lcd module connections
sbit LCD_RS at RB4_bit;
sbit LCD_EN at RB5_bit;
sbit LCD_D4 at RB0_bit;
sbit LCD_D5 at RB1_bit;
sbit LCD_D6 at RB2_bit;
sbit LCD_D7 at RB3_bit;
sbit LCD_RS_Direction at TRISB4_bit;
sbit LCD_EN_Direction at TRISB5_bit;
sbit LCD_D4_Direction at TRISB0_bit;
sbit LCD_D5_Direction at TRISB1_bit;
sbit LCD_D6_Direction at TRISB2_bit;
sbit LCD_D7_Direction at TRISB3_bit;
char m;
char result=0;
char tens=0,ones=0;
void code_enter(){
    kp = 0;       //Reset key code variable
    //wait for key to be pressed and released
    do
     //kp = Keypad_Key_Press();     // store key code in kp variable
    kp = Keypad_Key_Click();       // store key code in kp variable
    while (!kp);
    //prepare value for output, transform key to it's ASCII value
    switch (kp){
            case  1: kp = '1'; break; // 1
                        case  2: kp = '2'; break; // 2
                        case  3: kp = '3'; break; // 3
                        case  5: kp = '4'; break; // 4
                        case  6: kp = '5'; break; // 5
                        case  7: kp = '6'; break; // 6
                        case  9: kp = '7'; break; // 7
                        case 10: kp = '8'; break; // 8
                        case 11: kp = '9'; break; // 9
                        case 13: kp = 42; break; // *
                        case 14: kp = 48; break; // 0
                        case 15: kp = '#'; break; // #
    code1[i] = kp;
    i++;
    Lcd_Chr(2, i, code1[i-1]);// Replace key ASCII value by "*" on Lcd
//20ms delay function no need of it
void code_read(){      //read data from eeprom
     Delay_ms(20);
     user1[0] = EEPROM_Read(0x00);            // Read data from address 0
     Delay_ms(20);
     user1[1] = EEPROM_Read(0x01);            // Read data from address 1
     Delay_ms(20);
     user1[2] = EEPROM_Read(0x02);            // Read data from address 2
     Delay_ms(20);
     user1[3] = EEPROM_Read(0x03);            // Read data from address 3
     Delay_ms(20);
void code_write(){       //write data to eeprom
     Delay_ms(20);
     EEPROM_Write(0x00,code1[0]);           // Write data to address 0
     Delay_ms(20);
     EEPROM_Write(0x01,code1[1]);           // Write data to address 1
     Delay_ms(20);
     EEPROM_Write(0x02,code1[2]);           // Write data to address 2
     Delay_ms(20);
     EEPROM_Write(0x03,code1[3]);           // Write data to address 3
void change_code(){
     Lcd_Cmd(_LCD_CLEAR);           // clear display
     Lcd_Out(1,1, "Enter New Code:");
     i = 0;
        while(i != 3) {
                code_enter();
    code_write();
    delay_ms(20);
    code_read();
    delay_ms(20);
    Lcd_Out(1,1, "New Code Set");
    Delay_ms(5000);
void main() {
        ADCON1 != 0x07;
    ANSEL  = 0;                              // Configure AN pins as digital I/O
    ANSELH = 0;
    c1on_bit=0;                           // disable comparator
    c2on_bit=0;
    TRISC = 0x00;
    PORTC = 0x00;
    TRISD = 0x00;
    PORTD = 0x00;
    Keypad_Init();             // Initialize Keypad
    Lcd_Init();                              // Initialize LCD
    Lcd_Cmd(_LCD_CLEAR);                     // Clear display
    Lcd_Cmd(_LCD_CURSOR_OFF);                // Cursor off
    UART1_Init(9600);               // Initialize UART module at 9600 bps
    Delay_ms(100);
    code_read();
    Lcd_Cmd(_LCD_CLEAR);        //clear display
    Lcd_Cmd(_LCD_CURSOR_OFF);     // cursor off
    //Lcd_Out(1, 1, msg1);
    //Delay_ms(500);
    delay_ms(2000);
    cnt = 0;
        lcd_cmd(_LCD_CURSOR_OFF);
    if(user1[0] == 0xFF && user1[1] == 0xFF && user1[2] == 0xFF && user1[3] == 0xFF )
                EEPROM_Write(0x00,'2');               // Write some data at address 00
                Delay_ms(20);
                EEPROM_Write(0x01,'3');               // Write some data at address 02
                Delay_ms(20);
                EEPROM_Write(0x02,'4');               // Write some data at address 04
                Delay_ms(20);
                EEPROM_Write(0x03,'5');               // Write some data at address 08
        code_read();
        Lcd_Out(1, 1,  "WELCOME");
        delay_ms(2000);
        //Lcd_Cmd(_LCD_CLEAR);                      // Clear display
L1:  do{
        Lcd_Out(2, 3, "Press *");
        i = 0;
        code_enter();
        if(code1[0] == 42){      // *
                Lcd_Out(1, 1, "Enter Code");
                //delay_ms(500);
                i = 0;
                code_enter();
                code_enter();
                code_enter();
                code_enter();
                code_enter();
                if(code1[0] == '1' && code1[1] == '2'  && code1[2] == '3' && code1[3] == '4' && code1[4] == '5' ){      // master code
                        code_enter();
                        if(code1[5] == '#'){      // #
                                change_code();
                //else if((cnt<3) && (code1[0] == '2') && (code1[1] == '3') && (code1[2] == '4') && (code1[3] == '5') && (code1[4] == 35)){     // save password verification
                else if((cnt<3) && (code1[0] == user1[0]) && (code1[1] == user1[1]) && (code1[2] == user1[2]) && (code1[3] == user1[3]) && (code1[4] == '#')){     // save password verification           Lcd_Cmd(_LCD_CLEAR);                      // Clear display
                           lcd_out(1,1,"Enter the number");
                           lcd_out(2,1," of relay");
                           i = 0;
                           code_enter();
                           if(code1[0]=='1' || code1[0]=='2' || code1[0]=='3' || code1[0]=='4' || code1[0]=='5' || code1[0]=='6' ){
                                      Lcd_Cmd(_Lcd_Clear);
                                      Lcd_Chr(2,1,code1[0]);
                                      UART1_Write(code1[0]);
                                      delay_ms(500);
                                      i = 0;
                           else{
                                     Lcd_out_cp("error");
                                     delay_ms(1000);
                else{
                    Lcd_Out(1, 1, "Wrong Password");
                    Delay_ms(2000);
        } while(1);
Thanks jayanthd. Why did you have to use the uart module? Were you using an external eeprom?
I don't remember why I used UART but you can discard UART related code. No, I used internal eeprom. The code is mikroC PRO PIC code. I have used its libraries.
