technogeek
1.4 A off-line supply....
How do I select frequency, inductor size, and mosfet with minimising heat (or I guess maximising efficiency?) in mind?
If I run at 50khz, the current mosfet I have (I forget the part #) doesn't get warm at all. The diode and 1mH inductor hit 180F. The 1mH inductor is this part number: 2224-H-RC from JW Miller(bourns). The Rdc of the inductor is ~0.3 ohms, *1.4A^2 = 0.6 watts........ which doesn't make sense to me, because it seems like it is dissipating 2 or 3 watts.
Turn the frequency up to 200khz, mosfet gets hot (150F on the aluminum case). Diode stays about the same, the inductor got a little cooler, IIRC.
So, it seems like the ideal solution would be to minimise Rdc of the inductor and run at a low frequency. Problem is, 0.3ohm is the smallest Rdc of the 1mh inductor series. (without having to order 100+ of some less used line)
And when you run low frequency, you need a larger inductor. So it seems like either I'm going to have heat spewing out of the inductor, or the mosfet. Is that what Im getting here?
