Minimum Voltages
linguist
For an opamp like the TL072, how efficiently would this operate with a dual supply of
+8V & -4V.
I want to use a small single 12V battery & can get the voltages mentioned with it.
I have attached a picture of the dual supply, are their any other reasons this may not work?
I can get more positive voltage but then less negative voltage as a result.
Can I do better than this with just resistors?
Cheers
+8V & -4V.
Cheers
Use an OPA to provide a low impedance virtual ground, ie: +8v/-4v [or close]
Any opamp works from a single supply voltage if it is biased properly.
Most opamp circuits work perfectly when the reference voltage is half the supply voltage made with 2 or 3 high value resistors and maybe a filter capacitor. Then the input, output and feedback to ground also need capacitors.
Here is an example of the STICKY at the top of this page:
