I came across this schematic of a driver for a car spark coil, having built the driver it worked fine for about 3 short tests then one of the SCRs blew out. Clearly the amp draw is more than the capacity of it.
The type of coil I am using draws 5 amps with an inrush of 2x +. Can any one recommend an SCR that will fit the bill to replace the 100-8 and fit the application.
The application is peaceful………..I am building a plasma cutter and this is the igniter for the arc.
![110-Coil-1.png](https://chemelec.com/Projects/110-Car-Coil/110-Coil-1.png)
