The Boston Bruins are in the second round of the play-offs and my first
Basic program actually works! !
'SYMBOLS
Symbol led = RB0 'Define RB0 as LED
'START OF MAIN PROGRAM
TRISB = %11111110 ' Setup port b as RB7-RB1 inputs, RB0 as output
main: ' Label for beginning of main loop
High led ' Set pin 0 of portb high (5 volts) which turns the LED on
WaitMs 1000 ' Wait1000 milliseconds (1 second) with LED on
Low led ' Set pin 0 of portb low (0 volts) which turns the LED off
WaitMs 1000 ' Wait for 1 second with LED off
Goto main ' Jump to the main label and do it all again and again
End
The above turned into 119 lines in the LST file which, when
imported into MPLAB, built with a dozen errors and a ton of
warnings (naturally), then programmed into a PIC16F819
with an ICD2. Thank you much for all your help!
'SYMBOLS
End
