Menticol
Active Member
Hello everybody
I'm tryng to build a working FM transmitter.I have found some schematics on the net, went shopping, got the parts, and nothing!! no design seems to work
https://www.forosdeelectronica.com/about3674.html
This is the last one. Is in spanish, but the schematic is easy to understand even without the notes.
Some techical data:
Running at 10-15V
2N2222 Transistors
Strange pot, no idea if is the required 5-60 pF (the man on the store said yes)
Electret mic
The transformer is an air coil, 5 turns of common wire (steel wire, no isulation)
The antenna is made on the same material, 30 cms (1 feet) long
This is the story, if you wanna read:
I turned on the radio, put it 1 feet away, and started talking while slowly turning the pot. Nothing happens. Aprox at 96 Mhz (a random frecuency I selected) when I touch the coil the scratch on the radio changed. More interesting, puting my hand closer to my failed transmitter and the radio starts to receive a portugese program!!! I think my circuit doing the job of the old vacuum tube radios, with BC, SW1, SW2, SW3 and those strange frecuencies.
But I dont care, I just wanna get this thing working, as a normal FM transmitter!! How can I fix it?
Some techical data:
Running at 10-15V
2N2222 Transistors
Electret mic
