I need some help on using 60hz power to operate a clock removed from an aircraft that should use 400hz input. I have opened it up to see that the 115 VAC 400z is immediately stepped down with a transformer to 8VAC 400hz. The fuse protecting the input side of the transformer is .5 A and the one on the output side of the transformer is 2 A. The label reads that input required is 115VAC, 15W, 400hz. This clock was made by Seiko in 1982 and was mounted on the bulkhead in the cabin of a DC10. Its display is LEDs that show an Airport code, date and time for Tokyo and whatever other airport code you select. My first attempt to just try 115V 60hz blew the input fuse and my second attempt to tie in downstream with 7.5 VAC @500ma 60hz just gave me some mixed flickering of the LEDs. My goal is to convert this to a nice little desktop of wall mounted gift for someone, but I don’t want to spend a lot of money. I can get to all of the board to change a capacitor or something, but I don’t know what it will take. I am sure that the first circuit after the transformer is a rectifier circuit of some sort to convert to DC. I see a couple of SCRs or FETs or something and a big capacitor there. If I knew where to tap in with a feed in of some DC from a plug-in AC adapter, I could just cut out all of the 400hz part, I think (?). I have no 400hz power to hook up to it to search for voltages on the board, so that makes experimenting a problem.
Much obliged for any ideas.
