Posted on 6/08 asking about detecting a current flow in a 12VDC system. I got just the info I needed and quickly as well. Thanks very much for that. I have decided to use a Maxim 4372 current sense amplifier. Using this IC the Vout will varry depending on the current being detected. I am thinking of using Vout to turn on a transistor which will turn on an LED which would be the indication there is a current flow. I'm thinking Vout might be anywhere from 2 to 10 VDC. Could someone help with the circuit for the transistor and LED? All help appreciated.
