More simple questions...
2camjohn
Thanks to everyone who has answered my questions so far.
I have more questions though:
What configuration do I use to set up the internal oscillator in a pic 16f628 ?
What oscillator type do I choose ?
Is the internal one just as accurate as an external crystal ?
Anything else in the configuration I need to think about ?
Secondly what does the MCLR pin actually do? I have a resistor from it to +v but space is at a premium in my design can I replace the resistor with a normal copper track ?
Can I get away with just leaving it floating ?
John
It's done with the configuration word. You can eighter set it at programming time (tick the INTI selection in winpicprog) or modify your __Config statement in the source code.
No, The internal osc. is an RC oscillator, wich is not as accurate as a crystal. It will be accurate enough for most applications and, according to the datasheet, for serial communications.
The MCLR pin is a reset pin for the pic, It must be made high to make ther pic run its program, pull it low, and the pic resets itself.
The Pic16F628 you are using allows you to disable the MCLR pin (also done with the configuration word, disable MCLRE in winpicprog, or change your __config statement). Disabling this pin has 2 advantages. You no longer HAVE to connect it and secondly, the pin can now be used as an digital input
John[/quote]
