More than one controller for a PT100 3-wire element
Grossel
I have this issue where I have a quit simple, but important heat control system. It's actually a very simple system - if one or more of the PT100 elements reaches a certain temperature, the cooling activates and run until a lower temperature is reached.
There is a request to find out if it is possible to monitor the temperature in real time at another location.
So - this request would be doable if I could just remove the old control element and phurcase a PT100 to modbus converter. However - it turns out the facility is assembled in such a way that the old control panel cannot just be removed like that.
So the problems/limitation for now is as following:
  • The subject to be measured is assembled in such a way that it is impossible to just attach more PT elements (i.e sealed off).
  • The old control panel have to stay put for the foreseeable future.
  • New PT100 converter must use 24V supply voltage.
This is the solution - if it exist at all.
Due to practical company restriction - any solution must exist on marked today.
There must be a device that:
  • Accept one PT100 censor, 3-wire (or several groups of PT100 converters).
  • Two or more outputs - outputs must be isolated from supply voltage and use 3 terminals that resemble/simulates a PT100 element.
  • The output values must be equal and also be equal to the input (i.e. make one PT100 element to be seen as two separate ones)
Or - maybe you folks see another solution that I'm not seeing here ?
So one issue for me - I don't know what an English term for such device should be named. It may exist already, but I'm not able to find a reliable search phrase.
disclaimer : I'm trying to get familiar with some new features of Inkscape 1.3 so I couldn't resist putting in some 'symbols' in the drawing. Anyway, the drawing is only for concept.
