more transistor trouble
Alrightee. well, I've been trying to find an NPN Transistor with an Current gain above 140 and a maximum collector current at or above .7A in a T092, T0220, T0218, or a TO39 case (or just not something as large as a TO3 case)
I went to a local store, gave those values to the store owner, and came back with a few 2N3300's (the cross over from an NTE 123, which did fit the specifications, but was a little much for how many were needed). However, after looking at the datasheet for a 2N3300 it just won't fit the bill.
does anyone know of a transistor that would work in this position, but that won't break the bank?
(attached is a datasheet which has these values on them. also on it is the 2n2854, which I'm currently looking into)
  • TO-39 case small signal transistors.pdf
Look at DigiKey even if you don't intend to buy from them. They have a very good search engine for parts.
