MOSFET non-inverting buffer in an IC package
Rusttree
I'm using the schematic in the attached image as a non-inverting buffer. I'm using that buffer multiple times throughout my circuit to switch multiple different voltages. The input to the gate of the n-mosfet will be either 3.3V or 5V.
Does an IC product exist that is basically the electrical equivalent to that type of buffer? All of the IC buffers I've found are limited in some way or another. These are my requirements:
1. Less than 1.5mA current consumption.
2. 3V Vgs-on for n-mosfet
3. 3.3V, 5V, or 10V at p-mosfet source
Basically, I have multiple source voltages that I want to be able to switch on and off with logic level signals from a microcontroller. I already have my circuit laid out using multiple iterations of 2 mosfets and 2 resistors, but I'd sure love to condense the board up a little with some ICs. Can anyone suggest where to look?
Thanks!
Would a CD4066 do the job?
Thanks for your reply alec_t. I actually came across that part while searching, but I think it fails the on-voltage requirement for my circuit. The datasheet shows Vihc (control input high voltage) to be 7V minimum for a 10V signal. I need to be able to activate the 10V signal with 3V. Unless I'm misunderstanding the datasheet, I don't think that part will work for me.
I'm struggling a bit with this datasheet, but I think "Input High Voltage, Vih Min" is the minimum turn-on voltage. At 3.5V, that's just a little higher than the 3V I need =/. Thanks though! Let me know if I'm misinterpreting the datasheet.
Have you considered a quad comparator like LM339? You would need a pullup resistor on each output. A single logic threshold voltage could suffice for all comparators on the board.
Is the P-channel device a low resistance device intended to provide power to a load? If so, how much current?
