The second device is a logic level device. You can also tell these types of devices by the gate-source threshold voltage Vgs(th). In logic level devices it is generally 2.5 volts or less.
Easiest thing to do is use the parametric search on a manufacturers website to select a device with the basic properties you want for RdsON, Id, package, etc, and then see if the search returns any devices that are logic level drive.
devonsc said:The second device is a logic level device. You can also tell these types of devices by the gate-source threshold voltage Vgs(th). In logic level devices it is generally 2.5 volts or less.
Sorry if I'm asking nonsenseBut why it shows that the gate-source threshold voltage is 2V to 4V for IRF540N?
Real sorry, I guess I've understand what you mean after making some comparisons between IRL540N and IRF540N. Thanks a lot...
I've checked the prices, it seems that the prices for logic level MOSFETs are way higher than normal ones :cry:
