motion following robot (PIR sensors)
banterbot
Hello,
I am currently working on making a robot that follows movement (people walking is my aim). I am using a boe-bot kit with a Basic Stamp 2 along with 3 PIR sensors (one on the front, one on the left and one on the right).
So far I have the boe-bot constructed and everything's been tested and working; I just need to configure the PIR sensors so that when movement is detected by any of the 3 PIR sensors, the robot will follow the direction of that movement and when that movement stops, the robot will stop too.
So, for example, when the left PIR sensor is detected, the robot should turn left to face that movement and then follow it until the movement either stops or changes directions.
This is the code I have thus far, but I feel it's missing something(s). Perhaps someone knows of some revisions that may help make my robot follow direction more clearly.
' {$STAMP BS2}
' {$PBASIC 2.5}
DEBUG "Program Running!"
DEBUG "Initialize"
PIRDetectLeft VAR Bit
PIRDetectRight VAR Bit
PIRDetectFront VAR Bit
irDetectLeft VAR Bit
irDetectRight VAR Bit
pulseCount VAR Byte
DO
PIRDetectLeft = IN15
PIRDetectRight = IN12
PIRDetectFront = IN14
IF (PIRDetectLeft = 1) AND (PIRDetectRight = 1) THEN
ELSEIF (PIRDetectLeft = 1) THEN
GOSUB Turn_Left
ELSEIF (PIRDetectRight = 1) THEN
GOSUB Turn_Right
ELSEIF (PIRDetectFront = 1) THEN
GOSUB Forward_Pulse
ENDIF
LOOP
Forward_Pulse:
PULSOUT 13,950
PULSOUT 12,750
PAUSE 10
RETURN
Turn_Left:
FOR pulseCount = 0 TO 10
PULSOUT 13, 750
PULSOUT 12, 750
PAUSE 10
NEXT
RETURN
Turn_Right:
PULSOUT 13, 950
PULSOUT 12, 950
PAUSE 10
NEXT
RETURN
Back_Up:
PULSOUT 13, 750
PULSOUT 12, 950
PAUSE 10
NEXT
RETURN
