hello i need some help finding a circuit i can use for my diy motorcycle quickshifter.
for simplisity lets assume the triger is a push switch with a 12v feed. I need a circuit which once it receives the 12v signal from the switch closing it will create a pulse which grounds the coils cutting off the spark. the pulse needs to be variable (by changing a capasitor or somthing no need for anything complicated) between 50-100ms.
i have found this https://www.electro-tech-online.com/custompdfs/2013/08/MC14538B-DPDF.pdf
would that work? anyone know of any thing that would?
thanks for you help.
