Motorcycle turn signal canceler
MrDEB
here is a simple motorcycle turn signal canceler circuit that I have been working on. The circuit should time the turn signals at 10 seconds but is adjustable by R2 and R3
I have a pcb express fie for the pc board as well if you want.Board is 86mm x33mm
I originally designed using tip120 transistors but using the relay I think it will be easier to connect to the bikes wiring.
this circuit uses monetary push buttons to activate the timer.
my mistake
if thats the only mistake I make this month then perhaps I should put in for sainthood--lol
