jmricker
I need a little advice on how to mount a bridge rectifier.
I've been learning about electronics by reading the book Understanding Electricity and Electronics. The first project is to build a lab power supply that can be used to power other circuits. The book steps you through the project in each chapter and builds the supply in stages. I'm to the point where it explains diodes and how AC power is turned to DC power through bridge rectifiers.
So now I have to install the bridge rectifier. The instructions only say, "Assuming there were no problems with the bridge rectifier module, mount it, close to the T1 and T2 secondaries, with the appropriate hardware."
The bridge rectifier looks like this. I have several sizes of boards to mount it to, but I discovered that none of them had holes big enough to accept the terminals of this rectifier. I stopped into Radioshack but all the boards they had were the same size as I already had. I asked a salesperson and they said that what I needed was a heat sink. So I bought this one but now that I've gotten home with it, I'm not quite sure what to do with it.
So any advice? Maybe I can I flip it over, screw it to the case, and just solder my wires to each terminal? Or is there some better way? The case I'm using is an old DVD player so the bottom is all metal.
Joel
Joel
