Load voltage?
If these are current movements, then the usual technique is to get a voltage source and a potentiometer and adjust the pot for half scale.
You then measure the potentiometer resistance after making the meter read 1/2 scale. That's your internal resistance. From that and the voltage source, you know the full scale. current. Take I=V/R and 1V/(1E6+2*Rm) < 1uA minimum.
The 1E6 is a 1 M pot turned all the way up. 2*Rm is what you get at mid scale.
0 ohms for the variable pot isn't good, so you can also use a fixed resistor in series with a variable one.
I think I used a D cell. Just use the measured voltage.
A meter movement has its current for full scale and its resistance specified, not the voltage. A voltmeter is a current meter with a series resistor that limits the current.I'm concerned about the voltage popping the meter, even at 1.5 vdc
OK do it again, but give me the raw values:
The instructions are:
1) Connect the fixed resistor and the variable resistor initially at maximum and then adjust for 1/2 scale.
(you might want to set the pot so that (CW decreases the resistance) so the meter moves right with CW rotation.
2) Measure the voltage of the battery.
2a) As a check, measure the voltage across the resistor and the pot combination @ 1/2 scale
3) Remove and measure the (potentiometer + variable resistance) that it took to get to 1/2 scale.
A. Battery voltage (when at 1/2 scale) = ____ Volts
B. Voltage across (fixed + variable resistance @ 1/2 scale) = ____Volts
C. Resistance of (fixed+variable) out of circuit (that was used to reach 1/2 scale) = ____ Ohms
OK, I get: =1.59/(99.9+161.4)*2*1000 = 12.17
1/2 scale current = C3 = 0.526/99.9; Full scale current = C3*2*1000 or 10.53 mA FS
1/2 scale current = C4 = 0.868/161.4; Full scale current =C4*2*1000 or 10.76 mA FS
The meter resistance is (99.9+161.4) or 261.3
The 12.17 is off. If you measured the voltage not when the meter was at half scale might cause it. Measuring small value resistors you need to use the 4 terminal method.
You measure the current through, and the voltage across the resistor. The current is measured in nay part of the circuit. The voltage is measured
at the device terminals. Do you have a 4 or 5 wire ohmmeter?
The 2 is for half scale and the 1000 is conversion from amps/mA. C3 nd C4 are spreadsheet artifacts.
Around 10 mA nominal FS, I would believe.
Now, make a voltmeter out of it with a calculated series resistor. I wish you were more in the K range of resistors.
Yep I know tough time explaining. Numbers for 1 and 100 are easier to work with so 1e-3, e-6, e-9 get turned into mill-, micro- and nano-
One of the uses of ammeters is to change the full scale to volts or say a microamp meter to read mA. For that you need the meter resistance and the full scale current. That is the resistance of the of the "external element". The reason why it is the resistance because 1/2 the voltage is dropped across your external resistor & variable resistor and 1/2 across the meter.
Generally you can usually calibrate the zero and FS of the meter. Difficult, but possible.
If your using a traditional ohmmeter the lead resistance is probably at least 0.5 ohms *2. So, the 100.xx part of your measurements are not real. There is much to learn about accuracy and precision.
The resistor/voltage source method is pretty safe.
The 0-10A current meter must have a very low resistance shunt resistor that it measures the voltage across. If the shunt resistor is removed then the meter becomes sensitive voltmeter (most with a digital display have full-scale of 0.2V) then you can use Ohm's Law to calculate a new shunt resistance.
