bitem2k
Here is the problem code:
When I simulate this, for some reason the following code doesnt work properly.
For example, when LEDPORT equals 00000010, I call the above MOVLW, but instead of changing to 00000010, it changes to 00100010!
Whats going on?
thanks
;knight rider type thingy
LIST P=PIC12F629
include "P12F629.inc"
__CONFIG _CP_OFF & _CPD_OFF & _BODEN_OFF & _MCLRE_OFF & _WDT_OFF & _PWRTE_ON & _INTRC_OSC_NOCLKOUT
CBLOCK 0x20
SUBCOUNT
COUNT
LEDPORT
ENDC
PROGSTART
ORG 0x0000
SETUP_OSC
bsf STATUS, RP0 ;Bank 1
call 3FFh ;Get the cal value
movwf OSCCAL ;Calibrate
bcf STATUS, RP0 ;Bank 0
SETUP
BSF STATUS,RP0 ;CHANGE TO BANK1
MOVLW 0x00 ;SET W REGISTER
MOVWF TRISIO ;SET ALL PORTS TO OUTPUT
BCF STATUS,RP0 ;CHANGE TO BANK0
CLRF GPIO ;CLEAR GPIO REG
MOVLW B'111' ;DISABLE
MOVWF CMCON ;COMPARATOR
START
MOVLW 0x01 ;TURN first port
MOVWF GPIO ;ON
MOVWF LEDPORT ;SET LEDPORT
CALL DELAY
MOVELEFT
RLF LEDPORT, F ;SHIFT BIT LEFT(I.E LED)
;CHECK IF NEXT PORT IS GP3
MOVLW b'00010000' ;VALUE WILL BE USED FOR GPIO, IF PORT3 IS ACTIVE(I.E GP3 IS INPUT ONLY)
BTFSC LEDPORT, GP3;SKIP NEXT LINE IF ZERO
MOVWF LEDPORT ;SKIP GP3 AND MOVE TO GP4
BTFSC LEDPORT, 6 ;CHECK IF WE ARE AT THE LEFTMOST POSITION
CALL MOVERIGHT ;NOW START MOVING RIGHT AGAIN IF WE ARE AT LEFTMOST POS
CLRW
[COLOR=Red][B]MOVLW LEDPORT ;MOVE LED PORT BITS[/B][/COLOR]
MOVWF GPIO ;INTO GPIO REGISTER
CALL DELAY
GOTO MOVELEFT ;MOVE LED LEFT AGAIN
MOVERIGHT
GOTO START
DELAY
movlw 0xFF
movwf COUNT
DELAYLOOP
DECFSZ SUBCOUNT
GOTO DELAYLOOP
DECFSZ COUNT
GOTO DELAYLOOP
RETURN
end
Whats going on?
thanks
