Mr.K
How do I convert this code to work for MPLAB 8.1? props to bebe
LIST p=16F628a
include "P16F628a.inc"
ERRORLEVEL 0, -302 ;suppress bank selection messages
__config 0x3D18
cblock 0x20 ;start of general purpose registers
count ;used in looping routines
count1 ;used in delay routine
counta ;used in delay routine
countb ;used in delay routine
tmp1 ;temporary storage
tmp2
key ;which key was pressed
rows ;counter for number of rows
code1 ;registers for secret code
code2
code3
code4
key1 ;registers for keyed attempts
key2
key3
key4
endc
KEY_PORT Equ PORTB ;keypad port
KEY_TRIS Equ TRISB
Col1 Equ 0 ;pins used for keypad inputs
Col2 Equ 1
Col3 Equ 2
Col4 Equ 3
org 0x0000
goto Start
Start movlw 0x07
movwf CMCON ;turn comparators off (make it like a 16F84)
Initialise movlw '0' ;set 4 digit secret code
movwf code1
movlw '0'
movwf code2
movlw '0'
movwf code3
movlw '0'
movwf code4
SetPorts bsf STATUS, RP0 ;select bank 1
movlw 0x0F ;set keypad pins
movwf KEY_TRIS ;half in, half out
movwf TRISB
bcf STATUS, RP0 ;select bank 0
;Keypad subroutines
Chk_Keys movlw 0x00 ;wait until no key pressed
movwf KEY_PORT ;set all output pins low
movf KEY_PORT, W
andlw 0x0F ;mask off high byte
sublw 0x0F
btfsc STATUS, Z ;test if any key pressed
goto Keys ;if none, read keys
call Delay20
goto Chk_Keys ;else try again
Keys call Scan_Keys
movlw 0x10 ;check for no key pressed
subwf key, w
btfss STATUS, Z
goto Key_Found
call Delay20
goto Keys
Key_Found movf key, w
andlw 0x0f
call Key_Table ;lookup key in table
movwf key ;save back in key
return ;key pressed now in W
Scan_Keys clrf key
movlw 0xF0 ;set all output lines high
movwf KEY_PORT
movlw 0x04
movwf rows ;set number of rows
bcf STATUS, C ;put a 0 into carry
Scan rrf KEY_PORT, f
bsf STATUS, C ;follow the zero with ones
incf key, f
btfss KEY_PORT, Col3
goto Press
incf key, f
btfss KEY_PORT, Col2
goto Press
incf key, f
btfss KEY_PORT, Col1
goto Press
incf key, f
decfsz rows, f
goto Scan
;end of keypad subroutines.
Press return
Delay255 movlw 0xff ;delay 255 mS
goto d0
Delay100 movlw d'100' ;delay 100mS
goto d0
Delay50 movlw d'50' ;delay 50mS
goto d0
Delay20 movlw d'20' ;delay 20mS
goto d0
Delay5 movlw 0x05 ;delay 5.000 ms (4 MHz clock)
d0 movwf count1
d1 movlw 0xC7 ;delay 1mS
movwf counta
movlw 0x01
movwf countb
Delay_0
decfsz counta, f
goto $+2
decfsz countb, f
goto Delay_0
decfsz count1 ,f
goto d1
retlw 0x00
Key_Table ADDWF PCL , f ;translation table for keypad
RETLW 0x31 ;1
RETLW 0x34 ;4
RETLW 0x37 ;7
RETLW 0x2a ;*
RETLW 0x32 ;2
RETLW 0x35 ;5
RETLW 0x38 ;8
RETLW 0x30 ;0
RETLW 0x33 ;3
RETLW 0x36 ;6
RETLW 0x39 ;9
RETLW 0x23 ;#
RETLW 0x43 ;C
RETLW 0x44 ;D
RETLW 0x45 ;E
RETLW 0x46 ;F
end
