futz
Active Member
I've run into a few strange things in MPLAB v8.00.
1. The editor doesn't handle wrapped lines properly. After much confusion, involving, among other things, the cursor jumping semi-randomly to the top of code for no reason, I finally ended up just widening the editor window out till the lines I wanted to work on didn't wrap.
2. In this code snip (part of a much larger program) I have to leave a blank line after the "bnc a_30" command. If I leave the blank line out it doesn't assemble correctly (reads the following "movlw 0x31" as a comment).
It is possible this is being caused by a programmer error further up in the code, but I sure can't see it. The program assembles and runs correctly as long as that blank line is there.
showa movlw pa_val ;send "PORTA = "
call strsend
movlw 0x08 ;set bitnum counter variable
movwf bitnum
movff PORTA,temp1 ;save PORTA value in temp1
a_loop rlcf temp1 ;rotate bit into carry
bnc a_30 ;is the bit set?
movlw 0x31 ;yes, rs_send $31
call rs_send
goto a_bump
a_30 movlw 0x30 ;rs_send $30
call rs_send
a_bump decfsz bitnum ;decrement counter
goto a_loop ;counter not zero, go again
movlw 0x0d ;rs_send CR
call rs_send
movlw 0x0a ;rs_send NL
call rs_send
return
