kimimaro_kiddo
I am thinking of having a charger which can charge different battery voltages, for example 12V, 24V, 36V, and 48V. The charging process uses PWM signal to turn gate of MOSFET ON/OFF to deliver average power to the battery. In this case, I would need 4 different buck converter.
I was thinking, is it possible to design one buck converter which able to charge 4 different battery system. For example, 230V, 50-60Hz, supply is rectified to 120VDC and use it as input for the buck converter. by varying the PWM duty cycle, the average output voltage required can be achieved. is this possible?
another question is, what is the most efficient duty cycle for PWM signal? must it be always below 50% for most efficient result?
Regards,
Mike
Regards,
Mike
