multiplexed seven segment
bobparihar
i am doing a project in which i have to show counting from 0 to 99 on two multiplexed seven segments connected to a single port of 8051 ie. P2
my code is
C:
#include<reg51.h>
sbit a=P3^0;  // to on off seven segment
sbit b=P3^1;  // " " " " " (same as above)
void main()
   unsigned char ar[]={0x3F,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
   unsigned int i,j,k;
   while(1)
     for(i=0;i<100;i++)
       for(j=0;j<30;j++)
         a=0;        // on the 7 seg at tenth place
         b=1;        // off the 7 seg at ones place
         P2=ar[i/10];      // sending 0-9 to port 2 to 7 seg
         for(k=0;k<1275;k++);    // delay
         a=1;        // off 7 seg at tenth place
         b=0;       // on seven seg at ones place
         P2=ar[i%10];
     for(k=0;k<30000;k++);       // large delay for increment of number at ones place
the problem here is i am not getting the desired output on simulation..first the ones place shows and it increments after some delay the tens place shows and then goes to off.. though it shows counting from 0-99 but not in a desired way..
The multiplexing loop stops when the large delay k=....
starts.
You should place the multiplexing loop inside the large delay:
for i= 0 to ...
for k=0 to ...
{ for j=0 to ...
C:
#include<reg51.h>
void main()
   unsigned int i,j,k;
   while(1)
     for(i=0;i<100;i++)
       for(j=0;j<10;j++)
         P2=ar[i%10];
This runs reasonable...
Can I suggest that to prevent ghosting you swap the code to,
       for(j=0;j<10;j++)
         a=0;       // on the 7 seg at tenth place     Moved
         P2=ar[i%10];
         for(k=0;k<1275;k++);// delay
Also, if the count is too fast change the J loop to a larger value. E.G for(j=0;j<100;j++)
Ghosting is also known as no inter-digit blanking. I helped Fezder with this same issue on his blog. You have to turn the digit COMPLETELY OFF for a short time before setting up the segments of the next scanned digit.
