i'm trying to simulate this circuit in multisim 10...but I can't find some of the parts.
here is the parts list...with the parts I can't find in bold...is there an equivalent for these in multisim 10?
Capacitors
* C10, C11 - 15 pF mica
* C13, C14 - 100 uFd 100 V radial electrolytic
* C21, C22 - 47 uFd 100 V radial electrolytic
* C26, C27 - 270 pF mica
* C28 - 0.01 uFd 250 V film
Transistors
* Q1, Q2, Q5, Q7, Q9, Q10 - MPS8099 or MPSA06
* Q3, Q4, Q6, Q8, Q11 - MPS8599 or MPSA56
* Q23, Q24 - 2N3439
* Q22, Q25 - 2N5415
* Q26 - MJE15030
* Q27 - MJE15031
* Q28, Q30 - MJ15003
* Q29, Q31 - MJ15004
Diodes
* D5, D6 - 1N4934 fast recovery rectifier
* D13 through D16 - 1N5250B 20 volt zener diode
Resistors
* R13, R14 - 5.6 kohm 1 watt (This value is for 85 V power supplies. For other power supply voltages, the formula is on the Parts List page for the Leach Amp.)
* R28, R29 - 200 ohm 1/4 watt
* R30, R31 - 3.9 kohm 1 watt
* R37 through R40 - 470 ohm 1/4 watt
* R41 through R44 - 10 ohm 1/2 watt (changed 6/27/00)
* R52 through R55 - 6.2 kohm 1 watt
* R56 through R59 - 10 ohm 1/2 watt (changed 6/27/00)
* R60 - 39 ohm 1/4 watt
* R61 through R64 - 0.33 ohm 5 watt. These 4 resistors are mounted on the heat sinks between solder lugs on the power transistor sockets. The wires that connect the collectors of Q18 and Q20 and the collectors of Q19 and Q21 are also soldered between the lugs on the sockets. Keep all leads as short as possible and use insulation stripped from hookup wire around the bare leads of the resistors.
* R65, R66 - 300 ohm 1/4 watt
Capacitors
Transistors
* Q23, Q24 - 2N3439
* Q22, Q25 - 2N5415
* Q26 - MJE15030
* Q27 - MJE15031
Diodes
Resistors
