MultiSIM 74LS107
windozeuser
I'm currently designing a Shift register in MultiSIM; using two 74LS107's, and a 555 timer.
My problem is that the Pin 14 doesn't exist on the component it defined with Power 1 as VCC, but I need to connect it somewhere else....
I am using MultiSIM Version 8.3.3.0
Can anyone please look at my MultiSIM design (Attachment below), and see if you can see any problems? I know it's kinda messy with the auto routing wires.
Note I had to use 1N4001GP instead of 1N4001 (Can't find equiv)
And I used 100nF cap instead of 0.1 uF for C2
Also had to use 1N4735A instead of 1N4735 for D1
I'm only measuring like 107 pV for the LED's!
  • shiftregister2006.zip
It's actually a multisim file so somebody can load it up with multisim...
But I'll make a JPG real quick also.
Photo of circuit is below:
  • shiftregister2006pic.zip
  • shiftregister2006pic_213.zip
Even tho the 74LS doesn't have power pins, you have to tell it that it is connected to 5 volts. You don't have a 5 volt supply; it won't run on 9 volts. You need to find out how Multi Sim gets power to the part, or else make your own symbol with power pins.
Not sure how? I read the MultiSim Documentation I didn't find anything. Can any MultiSim expert help?
Thanks :D
UPDATE: I Noticed I didn't use pins 10 and 13 of the 74LS107D. I modified the model and changed them to ground and VCC respectively. Now The red LED's work, and the greens one's wont. Hey, atleast something works now...
