tsalapatas
HI all i am new to this site but i am doing my thesis and i have a serious problem and however i push my brain i cant find a solution.so i am building a circuit in multisim that get the sides of triangles and sqaures and then find the are in cm.i am using as my teacherr adviced me some shift registers and comparators 74ls85.My problem is that even though the connnection are correct when i run the simulation and i connect the oscilloscope to the the tree outputs of the comparator the results are : when a>b it shows correct that voltage is going through only that the same about a<b but when the inputs from both a and b are the same the oscilloscope shows that the voltage goes through a>b and a<b and not through a=b and however i change it no voltage goes through the a=b pin,can anyone help me its driving me insane thank you looking forward to hearing from all of you
