Yes, if the core material is suitable for use at that frequency.Can toroidal transformer be used with input signal of say 200mV amplitude and 2khz frequency at the primary to get stepped up output at the secondary? Does such level of voltage amplitude require thin wires?
The wire size is determined by the winding load current and the number of turns, not the voltage.Does such level of voltage amplitude require thin wires?
Audio transformer exists and they have lots of turns and thin wires. But I have not seen toroids in audio frequency range. Is there any limits on frequency range for using toroids and size of wire diameter relating frequency range, wire diameter and size of toroids?
