Hi there,
I have a PIC16F877A hooked up to a 4x20 lcd module and I am using the Extreme Electronics LCD library for MPLAB X. It works fine for a two line LCD but now that I have plugged in the 4 line LCD it will only display the first and third lines. If I take power away from the bread board and then plug it back in it display all four lines.
I included their library for your interest. I have set up my bread board with exactly the same pin outs as they stipulate.
I have had a look at the code and they run an initialise method before the LCD can be used. Just wondering if there is a particular set up that a four line LCD needs to operate properly? Is there something you need to know for this or is it something else. It would nice to have all 4 lines available.
Kind Regards Simon
Kind Regards Simon
