hi all
i have a problem with the LCD
my problem is that i don't know what is the wrong ,i write the program and test it using Proteus and the LCD is working on the program
i do double check the wire but no thing is happen all what i see is
a black boxes then after a while they dissapper, for pin 3 i do the voltage divier in order to get small voltage (less than 5volt),and same problem
i heard that the Proteus may not give the correct job....
this is my program :
#define F_CPU 8000000UL // crystal frequency in Hz
#include <ctype.h>
#include <stdint.h>
#include <stdio.h>
#include <avr/io.h>
#include <avr/pgmspace.h>
#include <util/delay.h>
#define setbit(port, bit) (port) |= (1 << (bit))
#define clearbit(port, bit) (port) &= ~(1 << (bit))
void my_delay(int ms) //Delay function
int i;
for(i=0; i< ms ; i++)
_delay_ms(1);
void write(unsigned char z) // function in inorder to write on LCD
PORTD=z;
setbit(PORTB,1);
_delay_ms(10);
setbit(PORTB,2);
_delay_ms(10);
clearbit(PORTB,2);
_delay_ms(10); //wait until the LCD finished execution
void startLCD()
//** 1) Set function set **//
PORTD=0b00111000; //0x38 in hex
clearbit(PORTB,1); //RS=0
_delay_ms(10);
setbit(PORTB,2); // enabled(toggel)
_delay_ms(10);
clearbit(PORTB,2); //unenabled
_delay_ms(10);
//** 2) display ON / OFF control **//
PORTD=0b00001111;
clearbit(PORTB,1);
_delay_ms(4205);
setbit(PORTB,2);
_delay_ms(10);
clearbit(PORTB,2);
_delay_ms(10);
//** 3) clear display **//
PORTD=0b00000001;
clearbit(PORTB,1);
_delay_ms(10);
setbit(PORTB,2);
_delay_ms(10);
clearbit(PORTB,2);
_delay_ms(10);
//** 4) Entry mode **//
PORTD=0b00000110;
clearbit(PORTB,1);
_delay_ms(10);
setbit(PORTB,2);
_delay_ms(10);
clearbit(PORTB,2);
_delay_ms(10);
int main()
DDRB = 0x06; // making pin (1) of port D as input and mask others
DDRD = 0xFF; // making all of port B pins as outputs
// delay until the LCD become Ready
_delay_ms(10);
_delay_ms(10);
startLCD(); // call LCD function
write(0x20);
write('A');
write('B');
return 0;
#include <ctype.h>
#include <stdint.h>
#include <stdio.h>
#include <avr/io.h>
int i;
_delay_ms(1);
PORTD=z;
setbit(PORTB,1);
_delay_ms(10);
setbit(PORTB,2);
_delay_ms(10);
clearbit(PORTB,2);
void startLCD()
_delay_ms(10);
_delay_ms(10);
_delay_ms(10);
PORTD=0b00001111;
clearbit(PORTB,1);
_delay_ms(4205);
setbit(PORTB,2);
_delay_ms(10);
clearbit(PORTB,2);
_delay_ms(10);
PORTD=0b00000001;
clearbit(PORTB,1);
_delay_ms(10);
setbit(PORTB,2);
_delay_ms(10);
clearbit(PORTB,2);
_delay_ms(10);
PORTD=0b00000110;
clearbit(PORTB,1);
_delay_ms(10);
setbit(PORTB,2);
_delay_ms(10);
clearbit(PORTB,2);
_delay_ms(10);
int main()
_delay_ms(10);
_delay_ms(10);
write(0x20);
write('A');
write('B');
return 0;
