Oznog
Active Member
I need to get a good storage cap for flashing a pretty big strobe tube.
I have noted that HV caps for camera flashes and strobes usually have a "photoflash" in their description, often marked on the cap. However this larger strobe tube requires a higher voltage than those camera flash caps. Of course two could be put in series but this will halve the capacitance, there are issues with keeping the voltage in the middle balanced. This would probably require more than 4 of these "photoflash" caps.
A cap like this would be perfect:
https://www.allelectronics.com/cgi-bin/category.cgi?category=140300&item=EC-1545&type=store
But it doesn't have a "photoflash" rating AND the tube has a 450V nominal voltage so it will need to be driven up there. The temp will be not be high though- temp strongly affects voltage ratings and that rating is probably for 105C. There is a significant voltage rating margin running 450V at say 35C. I will probably also need 2 caps which should halve the current from each cap which I think is the primary issue.
Any educated opinions on whether it will work in this duty?
