hfireworks
I have a power supply that has an input of 24vdc and has an output of 200vdc that charges capacitors. The power supply puts out 200vdc at 175ma before the capacitors.
My question is What is the power output through 220uf electrolitic capacitors rated at 250vdc from the power supply of 200vdc 175ma? and also with 100uf electorlitic capacors through the same power supply?
Will the current be constant at 175ma or will it be increased?
The capacitors put out a bigger charge than the normal power supply, but I don't know what the power output would be.
