Need for Help in vb.net..... please read
cena
Before I start my question, I would like to thank every member in the perfect website.
I’m working on my final project and I’m facing a problem.
I am trying to design a program that can detect the incoming call, receive data and display it by using MSComm (com3) in visual basic.net.
The program can detect the incoming call but the problem here that the program can’t receive the data and display it.
At the same time, the same program will receive data from 8051 in com1
I tried to change many things but still the program couldn’t receive the data.
If anyone can help me to solve this problem, I will be pleased for your help.
I attached this post with my program
Dim Phase As String
Dim Stage As String
Dim ReceiveBuffer As String
Const ReceivingInterval = 100
Private Sub Command1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Command1.Click
Dim strBuffer As String
Dim InString As String
Dim i As Integer
MSComm2.Settings = "9600,N,8,1"
MSComm2.CommPort = 3
MSComm2.Handshaking = 2
MSComm2.DTREnable = True
MSComm2.RTSEnable = True
MSComm2.InputLen = 0 'Default anyway
MSComm2.RThreshold = 1 'Fire OnComm event with a single character in input buffer
MSComm2.SThreshold = 1
MSComm2.PortOpen = True
Transact("ATE0", 300) 'command to tell the modem not to echo the "AT" back
Stage = "Initialising Modem"
Transact("ATS0=2", 300) ' Set Modem S0 register to 2 (Answer on two rings)
End Sub
Sub Transact(ByVal SendText As String, ByVal TimeOut As Integer)
WriteLog("Sending: " & SendText)
Timer1.Interval = TimeOut 'milliseconds
ReceiveBuffer = ""
MSComm2.Output = SendText & Chr(13) & Chr(10)
Timer1.Enabled = True
Phase = "Sending"
End Sub
Private Sub MSComm2_OnComm(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MSComm2.OnComm
showasc("OnComm: " & MSComm2.CommEvent)
Select Case MSComm2.CommEvent
Case 1 '1 Send event.
Case 2 '2 Receive event.
Phase = "Receiving"
ReceiveBuffer = ReceiveBuffer & MSComm2.Input
WriteLog("ReceiveBuffer: " & ReceiveBuffer)
Timer1.Enabled = False
Timer1.Interval = ReceivingInterval
Case 3 '3 Change in clear-to-send line.
Case 4 '4 Change in data-set ready line.
Case 5 '5 Change in carrier detect line.
Case 6 '6 Ring detect.
Case 7 '7 End of file.
'errors
Case 1001 '1001 A Break signal was received.
Case 1004 '1004 Framing Error. The hardware detected a framing error.
Case 1006 '1006 Port Overrun. A character was not read from the hardware before the next character arrived and was lost.
Case 1008 '1008 Receive Buffer Overflow. There is no room in the receive buffer.
Case 1009 '1009 Parity Error. The hardware detected a parity error.
Case 1010 '1010 Transmit Buffer Full. The transmit buffer was full while trying to queue a character.
Case 1011 '1011 Unexpected error retrieving Device Control Block (DCB) for the port.
End Select
End Sub
Function TrimLeft(ByVal Intext As String) As String
Dim Text As String
If Len(Intext) > 0 Then
Text = Intext
Do While Asc(Text) <= 32
Text = Mid$(Text, 2)
Loop
TrimLeft = Text
End If
End Function
Function TrimBoth(ByVal Intext As String) As String
Dim text As String
text = Intext
Do While Asc(Mid$(text, Len(text), 1)) <= 57
text = Mid$(text, 1, Len(text) - 1)
Loop
Do While Asc(Mid$(text, 1, 1)) <= 57
text = Mid$(text, 2)
Loop
TrimBoth = text
End Function
Dim line = 0
Sub WriteLog(ByVal Text As String)
strBuffer = TrimBoth(Text)
strBuffer = Text
line = line + 1
If Len(strBuffer) > 0 Then
Label1.Text = line & " " & strBuffer
End If
End Sub
Sub Listen(ByVal TimeOut As Integer)
WriteLog("Listening: " & TimeOut & " millisecs")
ReceiveBuffer = ""
Phase = "Receiving"
End Sub
Private Sub showasc(ByVal text As String)
Dim i As Integer
label2.Text = ""
label2.Text = label2.Text & " " & text & " "
End Sub
Private Sub Timer1_Elapsed(ByVal sender As System.Object, ByVal e As System.Timers.ElapsedEventArgs) Handles Timer1.Elapsed
WriteLog("Timer: Interval: " & Timer1.Interval & " Stage: " & Stage & " Phase: " & Phase)
Select Case Phase
Case "Sending"
WriteLog("Nothing Received")
Case "Receiving"
strBuffer = ReceiveBuffer
WriteLog("Received: " & strBuffer)
End Select
showasc(strBuffer)
End Sub
Private Sub DataIn()
Dim strbuffer As String
Do While True
Select Case Stage
Case "Initialising Modem"
If Mid$(strbuffer, Len(strbuffer) - 1, 2) = "OK" Then
Stage = "Setting S Reg"
Phase = "Sending"
Else
WriteLog("Modem not responding")
End If
Case "Setting S Reg"
Select Case Mid$(strbuffer, 1, 2)
Case "OK"
Stage = "Listening"
Phase = "Receiving"
Listen(100)
Case Else
'some sort of error
End Select
Case "Listening"
Select Case strbuffer
Case "OK"
Case "RING"
WriteLog("Incoming call")
ReceiveBuffer = ""
Case "CONNECT" 'The connect message may have some protocol information appended.
WriteLog("Connected")
DataIn()
End Select
End Select
Loop
End Sub
Function TrimRight(ByVal Intext As String) As String
'strip blanks, tabs, line feeds etc from end of string
Dim Text As String
Text = Intext
Do While Asc(Mid$(Text, 1)) <= 32
Text = Mid$(Text, Len(Text) - 1)
Loop
TrimRight = Text
End If
End Function
Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
ReceiveBuffer = ""
Label1.Text = ""
label2.Text = ""
Timer2.Enabled = True
End Sub
Private Sub label2_TextChanged(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles label2.TextChanged
End Sub
Private Sub dial_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles dial.Click
MSComm3.Output = "ATDT" + TextBox1.Text + Chr(13)
End Sub
Private Sub hang_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles hang.Click
MSComm3.Output = "ATH" + TextBox1.Text + Chr(13)
End Sub
Private Sub Button3_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button3.Click
TextBox1.Text = ""
End Sub
Private Sub RadioButton3_CheckedChanged(ByVal sender As System.Object, ByVal e As System.EventArgs)
MSComm3.PortOpen = True
End Sub
Private Sub RadioButton4_CheckedChanged(ByVal sender As System.Object, ByVal e As System.EventArgs)
MSComm3.PortOpen = False
End Sub
Private Sub RadioButton1_CheckedChanged(ByVal sender As System.Object, ByVal e As System.EventArgs)
End Sub
Private Sub RadioButton2_CheckedChanged(ByVal sender As System.Object, ByVal e As System.EventArgs)
End Sub
Private Sub MSComm3_OnComm(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MSComm3.OnComm
MSComm3.CommPort = True
MSComm3.Input = "cpa00000000" + Chr(13)
End Sub
Private Sub Button2_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button2.Click
MSComm2.Output = vbCr + "ATZ" + vbCr
End Sub
Private Sub Button4_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button4.Click
End
End Sub
Private Sub Timer2_Tick(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Timer2.Tick
Label1.Text = ""
label2.Text = ""
Timer2.Enabled = False
End Sub
End Class
try asking your question in a software related forum THIS FORUM IS FOR MICROCONTROLLERS just incase you can't read I think I've spelt it out
thanks (akg) for your post.
I post my circuit.
When the level switch (2) is 1 (logic 1), the 8051 gives a command to the modem to make a call. The modem will send the house phone number, date and time.
In the other side, my program in vb.net will detect that call by atuo answer and receive data from the modem and last thing that data will be displayed.
  • project.doc
i'm confused by ur posts. u have said that the program can receive data from 8051 , but it cannot receive data ["The program can detect the incoming call but the problem here that the program can’t receive the data and display it. At the same time, the same program will receive data from 8051 in com1 "], the 8051 is the interface between the pc and modem , right ..? so what is the problem.?
In my program in visual basic.Net, I use to com ports.
The first com port is only for the telephone line. In this case, I use com3 because my modem works with this port.
The second com port is only for serial port between 8051 and the computer.
My project has two microcontrollers (8051). The first 8051 is connected to modem, two water level sensors and valve. I attched the circuit for this section. When the low water level sensor gives logic 1, the 8051 give a command to the modem to establish connection with another computer through the telephone line and there are some information that the 8051 will send them to that computer which are: house telephone number, time and date. The other computer(I call it central unit) should receive the call and data, and then disply them. Every thing is fine, just only one thing I couldn't understand, the program detect the call, but it can't read and display the data. I used hypier terminal and I got all the data from the other modem.
The other 8051 is connected to many water flow sensors. The 8051 measures the pluses from every sensor at a time, then it will send the measurements to the central unit through the serial port (com1).
The program will receive all data from both 8051s and display it.
I'm sorry because I didn't explain the problem in a right way.
Thanks (akg) for your posts and help.
My modem responds correctly and the program detects the call. About comEvents, they are fine.
I think the problem is that the program can't read the incoming data from the buffer after detecting the call and I need command to clear the buffer after detecting the call and then, receive the dat.
Anohter point, if i tried to initialize the modem again, i will get error message.
these two statments contradicts.
if commevents are fine , u are getting the characters one by one . right ?
and u don't need to clear the buffer , because, as soon as data arrives in the modem buffer , it is transferred into OS buffer .
this happens because the port is open already , first close the port and then re-init.
